Maximum tire pressure?
Old 06-25-2016, 09:45 PM
GregLeo's Avatar
GregLeo
GregLeo is offline
Stage IV
Exclamation Maximum tire pressure?
I have a 2013 road king, normal cold pressure 36 front 40 rear. what is the maximum pressure i should allow? I ask this because I recently took a long trip with extreme changes in altitude and temperature. I could easily exceed 50 PSI in the rear while riding in the mountains in warm weather when it was cool and 1000 ft when i started for the day, normal warm tire increase on the rear tire is at least 5 PSI without air temperature or altitude change. ( I have a garmin TPS monitor and its been verified accurate).
Old 06-26-2016, 03:40 AM
gusotto's Avatar
gusotto
gusotto is offline
Always check the TP when cold, as you're doing.
Rising TP is normal when riding.
Old 06-27-2016, 06:43 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
You are suffering from information overload! As gusotto suggests check pressures when cold and ride. Your TPS is most use to you if and when it warns of a drop in pressure.
twoseas
10-01-2021 10:48 AM
Boostedboxer04
09-17-2018 07:59 AM
Mr.Softy
06-20-2018 06:21 PM
SWThomas
03-13-2015 04:22 PM
Jamman718
Wheels/Tires
11
06-29-2014 09:48 PM
Quick Reply: Maximum tire pressure?
