Help Needed: Upgrading to a 21 inch front tire.
As long as the New Aftermarket wheel is the correct fitment (2000-later "Touring" with 1" axle).
Re-use your Rotors (get new bolts) or buy new 11.5" rotors
Re-use your spacers
May need to drill out (2) fender holes slightly (i think the rears) to pivot the fender for better 21" tire clearance.
Re-use your spacers
It should be a change out if I buy the correct wheel for tge bike? Are their any additional parts I need to purchase? Will Ibe able to keep my caliper and rotor covers? How drasticly does it effect handeling? I am just trying to weigh the pros and cons before I pull the trigger on it and change it out.
I also lowered the front end 2". I also put on lyndall gold plus brake pads because I read factory pads will tear up the polished rotors.
I haven't riding yet so I don't know about handling yet. I purchased from kc international and heard some bad reviews but they were very good to deal with me. Wheel went on fine. Had a local tire dealer throw on a Avon cobra 120/70/21. I also took a dremmel and ground off the front stud on the fender for the tip light.
