Front Wheel Change
Old Apr 22, 2008 | 10:22 AM
melancon2008's Avatar
melancon2008
4th Gear
Default Front Wheel Change
Yes i bought a custom wheel for my sportster 1200 C . I currently have a 21" spoke. I am changing it to 19" with a 100 series tire. Will this tire and wheel fit my bike with out fender change? I all ready got the whell kit from Harley. They said it would fit with out Change
Old Apr 22, 2008 | 10:42 AM
schumacher's Avatar
schumacher
Default RE: Front Wheel Change
Yeh, it will fit.....but your fender may sit a bit high
Old Apr 22, 2008 | 11:25 AM
WVHogRider's Avatar
WVHogRider
ORIGINAL: schumacher
Actually, I believe the overall height of both tire/rim combos are almost identical. The fender should clear just about as it is with the 21"r. The 21" has a larger diameter rim, but almost no sidwall on the tire. The 19" rim is smaller in diameter, but the tire has the extra sidewall which balances out the size diference between the 19" & 21".
Old Apr 22, 2008 | 11:31 AM
melancon2008
4th Gear
Thanks Guys i appreciate the quick answers. Ya'll r alot of help
Old Apr 22, 2008 | 11:34 AM
hogsport's Avatar
hogsport
Now you have to post the pic of your new wheel !!
Old Apr 22, 2008 | 12:11 PM
melancon2008
4th Gear
I will take a pic and get it on. It's a pretty cool looking. Different!!!
Old Apr 22, 2008 | 01:46 PM
cHarley's Avatar
cHarley
I did the same thing and everything fit fine. The only problem I had is that the axle spacers are different and the ones supplied in the wheel kit did not fit. It took a bit of trial & error with an assortment of spacers to get the correct combination.
Unlike he 21" wheel, with the 19" and fatter tire you do need to unbolt the fender and move it out of the way to get the 19" wheel on & off.
Old Apr 22, 2008 | 01:50 PM
YodaddyKeith's Avatar
YodaddyKeith
POST a pic!
I just ordered these 10 minutes ago
http://www.hammercustomcycles.com/Vi...umber=W21MLTS5
Old Apr 22, 2008 | 07:05 PM
SportyPig's Avatar
SportyPig
ORIGINAL: cHarley
I've never had to do that, but itis TIGHT. It would probably be easier to get the fender outta the way, than messin with the tight fit.
Old Apr 22, 2008 | 07:18 PM
cHarley's Avatar
cHarley
ORIGINAL: SportyPig
ORIGINAL: cHarley
Maybe cause the Metz tires run a bit narrower???
