Softail rear wheel
02-12-2017, 07:38 AM
02-12-2017, 11:16 AM
Our experience shows us that a 210/50-17 will fit in back, so your 200/50-18 should work as well. Check installed tire dimension specs for whatever rubber you'll run back there to be sure, as things are gonna be close.
02-12-2017, 09:38 PM
Anyone know on the wheel listed?
02-13-2017, 12:01 AM
Linky, No worky
02-13-2017, 12:08 AM
02-13-2017, 01:57 AM
No, that wouldn't be a direct fit
It's a 99-earlier wheel
- Taper roller wheel bearings
- Smaller pulley/rotor locators on hub
- Narrower hub
A person could make it fit, but you would have to "work" at it
02-13-2017, 06:26 AM
02-13-2017, 06:30 AM
02-13-2017, 03:34 PM
That may work...if you can't get an "application" then...
I would get a few measurements from your existing wheel...
- mounting surface-to-mounting surface (rotor and pulley)
- outside bearing-to-bearing
- wheel offset (2 different center-lines)
svarnster
10-31-2017 11:55 PM
TrainMan06
Softail Parts
01-05-2015 12:42 PM
Tony397
Wheels/Tires
07-17-2011 08:06 PM
tire_fryin89
Wheels/Tires
08-07-2010 09:19 AM
TxBandit
08-13-2007 11:21 AM
