1992 HD Softtail Springer FXSTS
Old 02-23-2017, 08:17 AM
Motogal's Avatar
Motogal
Motogal is offline
Stage II
Default 1992 HD Softtail Springer FXSTS
I have a 1992 Softtail Springer that I am modding and I need help determining wheel size and tire size.
I am removing the rear fender and am putting a chain conversion kit on it and open primary. I am also removing the front fender. I am shortening the springer 1.5"
This bike will be a tracker style bike.
I am wanting to put an 18 on the rear. Stock is 130/90-16
I am wanting to put either and 18 or 21 on the front. Stock is 80/90-21.
The wheels I am purchasing are either 21x2.15 or 21x3.5, and 18x3.5. I just can't figure out what I can get away with. Please help
Old 02-23-2017, 01:12 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,241 Likes on 1,817 Posts
Well the widest tire for the 21x2.15 would be 90/90-21. You could use a 120/70-21 or 130/60-21 on the 3.5. For the rear 18x3.5, you could use a 150/70-18 depending if you have clearance for the fender and that old 1.5" wide belt
Old 02-23-2017, 04:18 PM
Motogal's Avatar
Motogal
Motogal is offline
Stage II
I am contemplating if I can do a 21 that is 3.5" in diameter up front. And I'm doing a chain conversion and doing away with the stock fender. Thoughts?
Old 02-23-2017, 04:43 PM
multihdrdr's Avatar
multihdrdr
Having No fenders and a chain drive should help with clearances
I would check with the Tire manufacturers for their particular tire width, but using Nominal sizing... can you fit a 120mm (4.72") or 130mm (5.12"), and 150mm (5.91") is their respective areas?
Beemervet
Wheels/Tires
12-10-2017 09:50 PM
frostyflh
05-22-2017 02:55 PM
Rocker_Dan
04-14-2013 08:09 AM
bikerbehaviorist
Wheels/Tires
01-11-2009 12:12 AM
Bikermike
05-31-2006 12:45 AM
Quick Reply: 1992 HD Softtail Springer FXSTS
