Custom wheel tire pressure question
After recently upgrading my wheels on my 06 SG , I realize that I should probably ask around to see what the proper air pressure I should be running would be..
Rims are billet, tires are Avon, pretty much stock 06 SG, Im 190lbs..
running front 120/70-21 avon cobra
rear 150/70-18 avon roadraider
Any suggestions?
Any suggestions?
That's guessing! When changing brand, whether to stock or custom sizes, it is wise to check the manufacturer's website, from which we can see that a good starting point would be around 40F/44R. It's well worth doing a little experimentation around those numbers. My own experience is to use slightly higher pressures rather than lower.
