2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Gearing change on the Rushmore bikes???
Old 10-04-2014, 04:37 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
Default Gearing change on the Rushmore bikes???
I had been wondering abut something and confirmed it today. There seems to be a gearing change on the Rushmore bikes. At least on the '15s. On my '15 I am hitting 3000 RPM at around 64mph. On a buddies 2012 you don't hit 3k until around 70. Which is what I remember on my 2013 RGU. Would there be any way to get that back on the '15 such as a sprocket change??? I don't like having to feel like I need to shift to 6th below 70 because the way traffic is around here I find myself bouncing between 5th and 6th constantly. I would rather be shifting into 6th on long stretches of open slab.
Old 10-04-2014, 08:07 PM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
something wrong there, My 14' runs 80mph at 3000 rpm
Old 10-04-2014, 08:13 PM
RK_2014's Avatar
RK_2014
RK_2014 is offline
Old 10-04-2014, 08:28 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
Me too
Old 10-04-2014, 08:35 PM
RushKing14's Avatar
RushKing14
RushKing14 is offline
I assume you are hitting 3k at that speed in 5th gear? 6th gear should give you 80 MPH
Old 10-04-2014, 09:48 PM
14Glide's Avatar
14Glide
14Glide is offline
6th gear?
Old 10-04-2014, 11:39 PM
06SGWA's Avatar
06SGWA
06SGWA is offline
Sounds like he's using 6th gear as an overdrive, and only occasionally. Your 103 has plenty of torque for highway speeds in top gear, no need to downshift.
Old 10-05-2014, 12:40 AM
RushKing14's Avatar
RushKing14
Now that I think about it, 5th gear at around 64 is about 27-2800 maybe, and I don't hit 3K in 5th until just under or at 70. Maybe the OP is on to something. 6th at 3k is for sure 80 on mine though.
Old 10-05-2014, 05:15 AM
Garemlin's Avatar
Garemlin
Garemlin is offline
Sorry should have been more specific. I meant I hit 3k at around 63-64 in fifth gear. On my '13 and my buddies '12 you don't hit 3k in 5th until around 70. It is similar to the gearing when the 6 speeds first came out.
Old 10-05-2014, 06:31 AM
skieverything's Avatar
skieverything
skieverything is offline
I don't know about all you guys, but at 60-65 in 6th gear I have plenty of pep , no need to downshift. My opinion
Quick Reply: Gearing change on the Rushmore bikes???
