Am I the only one? (Hand brake)
I have yet to use or apply the foot brake, over 5000 miles and I don't see a need for It. Linked system Is awesome.
Seems pretty dangerous at slow parking lot type speeds
He's referencing the new linked ABS on Rushmore models: Reflex linked ABS brakes (optional on the base Street Glide). The system is unusual in that it electronically adjusts the overall proportion of linking, both front to rear and vice versa, based on how the rider is using the brakes. If you’re an expert braker and applying appropriate amounts of front and rear pressure, Reflex will assist you very little. If you have poor technique, Reflex will assist you by adding brake pressure where it can most effectively be used, shortening stopping distances and enhancing safety.
I've never driven a Rushmore, but guessing OP's not using a whole lotta front brake in parking lots...they're referring to regular stops. I'd have to say I agree with Rustrtal's comment tho, on the fact you're getting used to hitting "front" bake more than both by habit so...what happens in a panic-stop situation? |
Not linked under 20 mph
With my 2014 FLHTK, I have the perception that if I use the front brake only, the forks seems to “dive” more. It might be true or it might be because the system is more sensitive to the same amount of lever movement thus making the front levers more sensitive. I have been trying to use the rear brake only with in a slow turn (if needed).
I have a bad knee so I tend to put both feet down within 30’ of my stopping point…thus using the front brake. Perhaps the linked system does not apply equal pressure to both front and rear but will favor which ever lever you apply pressure to. I have read no literature about this yet. Perhaps someone of greater knowledge could chime in. |
I use both brakes and ignore the fact that I have linked brakes, If the computer wants to intervene and help me out, Fine. Otherwise I will not practice poor riding habits thinking the computer will take care of me.
Originally Posted by sixguns
(Post 13392351)
Sounds very logical to me. |
(Post 13392351)
The linked brakes on the new Rushmore bikes do not engage if you are under 20-25 mph per HD. But, they work real nice when you slam on the brakes at 70. :icon_goofygrin: I test road a 15 Road Glide (not special model) and slammed on the brakes around 75, back end started sliding out. Forgot it didn't have the linked brakes. Did it on a 15 Street Glide Special with linked brakes, stopped in a dam hurry. No back end sliding out either. Very nice setup IMHO. |
I use the brakes on my Limited just like I have for every other bike I have owned. I just notice that the bike handles much better when I do. Besides, my Heritage does not have linked brakes and I need too keep habits that work with both bikes.
Originally Posted by NDBadlands4-2
(Post 13392459)
© 2024 MH Sub I, LLC dba Internet Brands
