Dealership labor hours for 110" drop in kit
Just curious as to what everyone else has been quoted by the dealership for labor hours for this kit.
mechanical repairs are almost never "actual hours".
a rate is established for how long the job should take and the job is billed as such. a tech who can work efficiently and do right the first time can make more, a slow tech ( or one who has call-backs) will make less. For H-D, the H-DMC usually establishes the time billed. In automotive shops. the Mitchell Manual is the most often used source. when reading an estimate or invoice make sure you are not being billed twice for portions of the job. For instance if you are paying to "replace the battery" you should not be billed to "remove the seat". Removing the seat is already accounted for in the time rate established. Same with "replace belt" assumes that the swingarm is removed and outer, primary drive, clutch, compensator and inner primary are removed. You should be able to get a time quote from any number of dealers and then X by their own shop labour rate. Be aware that extra charges can come from seized, rounded off bolts, added accessories which complicate the procedure or general poor condition. anything which increases the time and effort it takes to perform the repair. This is the reason that many dealers will not work on older bikes mike |
Was there a number in all that?
Just kidding. I don't know exactly, but I recall reading 8 or 10 hours *i think* |
Originally Posted by Mchad
(Post 15813594)
Well, if the dealer was giving you any kind of warranty with those extra 3 hours, it may be worth it?
(Post 15815357)
Originally Posted by rhuff
(Post 15812847)
(Post 15814415)
Lol.........I was thinking the same thing. I thought I recalled that as well. My dealership said 13 hours, which I figured was WAY to many...... I think if I go that route, I'll be looking to an indy anyway to install.
I was able to find a former Harley Davidson Machanic through a friend who charged me $625. For the installation including all the new synthetic oil with it.
What about the tune? Is that included with the installation?
© 2024 MH Sub I, LLC dba Internet Brands
