2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Navigation issue
Old 08-26-2017, 07:48 AM
RollaMo's Avatar
RollaMo
RollaMo is offline
Originally Posted by stro1965
New radio installed today. Zero change. This one behaves exactly like the last one. Takes a good 5 minutes for it to find satellites. So frustrating!
That sounds more like an antenna issue.
Did they replace that too, or just use your original sat antenna?
  #32
Old 08-26-2017, 03:13 PM
stro1965's Avatar
stro1965
stro1965 is offline
I replaced the antenna before the radio.
  #33
Old 08-26-2017, 10:12 PM
CVO SG's Avatar
CVO SG
CVO SG is offline
New antenna, new radio. No change. That's odd. Only thing left that I could think of would be the antenna placement or interference from something like an amp??
Edited
Is the issue still of the time to locate sat or it being off on your location? Mine has always taken a couple min to lock on satellites before it'll work.
  #34
Old 08-27-2017, 01:34 AM
stro1965's Avatar
stro1965
stro1965 is offline
Edited
I moved the antenna up to the dash, as far away from the amp as I could. It does eventually lock on to satellites, and works fine once it does, but it takes 3-5 minutes to lock on. Makes it tough to lead group rides.
  #35
Old 08-24-2018, 07:11 AM
dynoflyer's Avatar
dynoflyer
dynoflyer is offline
Default NAV Screen magnification issue
On long stretches of road I try to adjust the magnification by setting the view to a very wide area to see upcoming turns, towns, etc. It always goes back to a very narrow view withing a few seconds. The narrow view only shows a small area view, like two or three city blocks. I've tried both 2D and 3D view but doesn't help.
Is there a way to expand the view and keep it like that so it doesn't revert to the small area? It's a '14 SGS with the 6.5 Boom Infotainment. Thanks.
  #36
Old 08-24-2018, 09:33 AM
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is offline
Do you have Auto-Zoom turned on? It will do this if A/Z is on, IIRC you can turn it off by going into that little box (3 lines) on the navi screen, scrolling down to "preferences" and turning A/Z off.
dynoflyer (08-24-2018)
  #37
Old 08-24-2018, 11:25 AM
dynoflyer's Avatar
dynoflyer
Thanks Rob, found it and that's the solution.
  #38
Old 08-24-2018, 11:37 AM
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is offline
You're welcome, glad it worked!
  #39
Old 06-26-2019, 08:03 AM
fredhof's Avatar
fredhof
fredhof is offline
1st Gear
I'm having the exact same problem with my 2017 Road Glide Infotainment system. The GPS thinks I'm 48-60 miles away -- which obviously makes navigation quite useless. I brought it in to HD when the bike was still under warranty, and they did some software update that corrected the problem...temporarily. Pisses me off to have a GPS system that DOES NOT WORK,
  #40
Old 06-26-2019, 10:40 AM
stro1965's Avatar
stro1965
stro1965 is offline
For what it’s worth, mine still doesn’t work! I feel your frustration!
fredhof (06-27-2019)
Quick Reply: Navigation issue
