iPhone X and the Limited dash compartment
Would you not get one if it didn't fit? I would.
talkingrock (08-20-2020)
A "7" has lots of extra room in my SGS, more than enough room for a "X".
I have the iPhone X in an Otterbox Symmetry case. It’s not bulky and the phone fits. Problem is when you connect the USB cable to the phone, i can’t close the door to cubby hole. Pulled the foam piece and it still wouldn’t fit. I did not pull the phone from the case. It might fit without the case but it’s going to be damn close. Just depends on what usb connector you have for the phone. If you’re not plugging the phone in then it fits. The iPhone X is longer than a 7 or 8.
Harleyrib maybe your Otterbox case is the problem. I found these stats on the apple website. My iPhone 6 is the same size as the 7 and 8 and I have plenty of room left over and it wears a Speck case.
Any ways thanks for your response.
Size and Weight
Height
5.65 inches (143.6 mm) iPhone X
Height
5.45 inches (138.4 mm) iPhone 7/8
Width
2.79 inches (70.9 mm) iPhone X
Width
2.65 inches (67.3 mm) iPhone 7/8
Depth
0.30 inch (7.7 mm) iPhone X
Depth
0.29 inch (7.3 mm) iPhone 7/8
Weight
6.14 ounces (174 grams)iPhone X
Weight
5.22 ounces (148 grams) iPhone 7/8
Size and Weight
Height
Height
Width
Width
Depth
Depth
Weight
Weight
Size and Weight
Height
Height
Width
Width
Depth
Depth
Weight
Weight
Size and Weight
Height
Height
Width
Width
Depth
Depth
Weight
Weight
