2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Is there a secret to this??
Old 06-23-2018, 03:05 PM
dave the welder's Avatar
dave the welder
dave the welder is offline
Originally Posted by Screamin beagle
You can get a plastic tray from the dealer...insert groan and eye roll here...that slides up under the filter and if you're careful will catch most of the oil. I loosen my filter first then stick that tray under and add some paper towels under it near the filter to catch any oil...works pretty good
I use this, once its in position take a sharp awl or punch or drill. And make a hole at the bottom of the filter. The filter will drain out in a couple of minutes and it will be no mess.
Old 06-23-2018, 05:38 PM
GoodToBeTheKing's Avatar
GoodToBeTheKing
GoodToBeTheKing is offline
1st Gear
Don't waste your money on that orange thing sold by Harley. It doesn't go far enough under the oil filter and the rubber tube doesn't stay attached. Get a sheet of stiff cardboard or plastic and slide it under the oil filter, be sure to push it far enough back to catch the oil when you loosen the oil filter. Make it long enough to extend past the floor board, so the oil that it catches can drip into a pan.
Old 06-23-2018, 06:11 PM
Highwaymans's Avatar
Highwaymans
Highwaymans is offline
Ive tried everything. Poke a hole, blow air thru it, towels, aluminum foil, the goofy harley thing...... It doesnt work.....
What did on my Dyna and Bagger? DK filter relocate. Otherwise rag it best u can and get some cans of brake clean for clean up.
Old 06-24-2018, 05:42 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
Gear oil bottle; the oil and filter drop right in. I've been thinking of painting them orange and black and selling them for $49.99
Old 06-24-2018, 08:15 AM
GOV5's Avatar
GOV5
GOV5 is offline
Received 1,451 Likes on 932 Posts
What's wrong with putting a plastic grocery bag over the filter....loosen it...then let in fall in the grocery bag. No spill, and the filter is in the bag and can be dumped into the garbage can.
Old 06-24-2018, 08:18 AM
barneyboy's Avatar
barneyboy
barneyboy is offline
Received 2,630 Likes on 1,533 Posts
All of the above suggestions will reduce, or eliminate the mess. If you go the homemade route, the best time to "tweak" your funnel is after you remove the filter. Without the filter in the way, you can see what will work best for your bike. A little trimming, and test fitting will result in a near perfect fit for future use.
Old 06-24-2018, 09:38 AM
Mickeetwo's Avatar
Mickeetwo
Mickeetwo is offline
I have found the rag method works the best for me. I've tried all the others and I still make a mess.
Old 06-27-2018, 08:10 AM
Magnut1's Avatar
Magnut1
Magnut1 is offline
Received 1,693 Likes on 827 Posts
I found if you do this at your buddy's garage, you won't make a mess on your floor, LOL
Campy Roadie (06-28-2018)
Old 06-27-2018, 08:19 AM
DamifIknow's Avatar
DamifIknow
DamifIknow is offline
I make a new one of these from a piece of cardboard every time I change oil.
Old 06-27-2018, 08:21 AM
DamifIknow's Avatar
DamifIknow
exactly this^^^^^
Quick Reply: Is there a secret to this??
