2015 RG has no power
Just because you don`t read voltage on the bad bike does not mean the BCM is bad.
It may be that the BCM is not getting power.
You must check to see if power is being supplied to the BCM.
Has this bike been running ok up until now?
Has any work been performed on the bike lately?
I get that but the known good bike is putting out 12v on that wire. The other side of the switch is ground.
On the bad bike we have 12v going into BCM on the single wire plug going into it, but nothing coming out. I'm gonna go with the BCM and see what happens. It's not like HD hasn't had any failures on them.
In order for power to come out of the BCM, it must first GO INTO the BCM.
I don`t know why you posted here in the first place, you already made up your mind you were going to take a chance with someone else`s money...
The following 3 users liked this post by Dan89FLSTC:
