2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
Old 12-06-2013, 10:29 AM
14 FLHX's Avatar
14 FLHX
14 FLHX is offline
Default Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
I ordered the BCM Complete LED Turn Signal Conversion Kit, part # GEN200-KIT-BCM and the 8" Red Mega Plasma Rod (pair) part # GEN-MPLASMA-RED-PR, I also added 2 of the PDC (plasma dual converter) so i can use the rods as Run, Brake & Turn. Part# TFC3
The Led lights are easy to do, just pop off the lens cover with a penny or screw driver (there is a slot) then undo the bulb and toss in the led light, There is a slot for a screw driver as there is no bulb to grab onto to twist it in. Then twist the light to wrap up the wires. Here is where i did a mod, the directions said I MIGHT have to trim the plastic gasket for the cover to snap on. I didn't like that idea, my thought was i might let moisture in, so i took out my belt sander and sanded down the taps just a touch so they weren't binding up with the gasket.
So here are some before picture of stock lights
Running lights
Brake lights
AFTER
UP CLOSE YOU CAN SEE THE HALO
LED RUNNING
LED BRAKE
Now for the Plasma Rods.
I did some searching as to how to attach these lights and there are a few different ways.
One way i found was to attach a piece of 3/4'' round wood on the plastic fender. https://www.hdforums.com/forum/touri...asma-rods.html
I wasn't liking that too much, I also found that a guy filled the cavity with silicone and stuck the plasma light to that.
I wanted a way that i can remove the light if i wanted to without making it a big deal, You never know i might want a new bike again in a few years.
Well i decided i wanted to use the existing bolt holes on this bracket for my mounting area.
I went to menards and bought a piece of flat stock that fits just perfect inside the bracket. I then used some 1\4" bolts.
Old 12-06-2013, 10:41 AM
14 FLHX's Avatar
14 FLHX
14 FLHX is offline
So now i bolted them on with nylon lock nuts and stuck the plasma rods to it.
Time to wire them up.
I tucked the wires in and zip tied them up.
Now its time to Install the PDC, it has a single red on one side and a orange and red on the other.
I soldered the single red to the red from the plasma rod
Then I put a ring connector on the two black wires from the plasma rods and connected it to the battery.
Now here its where you have to get the right wires to get the run, brake and turn to work properly.
Orange wires go to the solid BLUE wire, Left rod RED gos to the BLUE-PURPLE on the bike, Right rod RED goes to the BLUE-BROWN on the bike.
here is where i made my connection, i didnt want it back by the tire as there is much more chance of moisture and problems down the road.
Old 12-06-2013, 10:44 AM
14 FLHX's Avatar
14 FLHX
14 FLHX is offline
Some pics of the completed Job
Bags on running
Brake
In a completely dark garage.
Running
Brake
Let me know what you think...
Old 12-06-2013, 10:53 AM
Dr.ultra2010's Avatar
Dr.ultra2010
Dr.ultra2010 is offline
sweet.. I like it
Old 12-06-2013, 11:03 AM
vonzoog's Avatar
vonzoog
vonzoog is offline
Very nice write up.
FYI: For those who wish to use 3/4 round molding for mounting, I agree with 14FLHX. Using wood molding would not be a good choice. I used the newer style (Cheap) plastic molding that can be found at any home hardware store. It will never deteriorate over time like the wood molding would.
Old 12-06-2013, 11:06 AM
Its time to ride's Avatar
Its time to ride
Its time to ride is offline
Well done! I think it looks good enough that i'm gonna have to try it!
Old 12-06-2013, 11:58 AM
twr3cks's Avatar
twr3cks
twr3cks is offline
Looks fantastic, and thanks for the write up!
Old 12-06-2013, 12:17 PM
offthewall's Avatar
offthewall
offthewall is offline
I love the "over-kill" nature of your mounts! You ought to market those.
I was actually thinking of just layering up two or three layers of rubber weather striping in the valleys of those mounts on the bike, then sticking the Plasma rods to it.
Old 12-06-2013, 12:18 PM
bill1nat's Avatar
bill1nat
bill1nat is offline
That is really awesome, Thanks for the time and pictures.I might have to try this on my limited!!!!
Old 12-06-2013, 12:35 PM
PopsHD's Avatar
PopsHD
PopsHD is offline
Not sure what I am more impressed with, the LEDs or your workshop and the tools in it.
Quick Reply: Custom Dynamics LED and Plasma Rods Install on a 14 Street Glide Warning Lots of Pics
