14 FLHTK Clutch Problems again!!!
I have 675kms on this bike. Saturday, the clutch master cylinder decided to stop working. Out of the blue I had no clutch. Luckily, I wasn't far from home and limped back without incident Just got off the phone with the dealer...they confirmed the recall was done prior to delivery, but are now saying that it sounds like I'll need a new master cylinder. Is anyone else having any problems after the recall work???
Thanks.
Thanks.
I've put 1500 miles on mine since the recall was performed. No issues.
You can go on the HD website and punch in your VIN and see if there's any info there.
https://www.harley-davidson.com/en_U...bmLocale=en_US
What color should the brake fluid be in the clutch master cylinder? Mine is cloudy grey...
Dealer has sent me a technical service bulletin that states the lower clutch cylinder could be leaking on the right side of the transmission where the clutch line connects. Mine looks dry down there. Their next solution was to drain the fluid completely and refill it to eliminate any air. Number 1...where did the air come from if that's the problem? Number 2...If it was air, wouldn't it pump up after several pumps? I get nothing at all. I had the cover off the master cylinder and slowly squeezed the clutch...no air bubbles. The dealer said Master Cylinder, but they called Harley and the moco told them it couldn't be...it has to be air in the fluid or a leak at the bottom. Has anyone had any problems like this?
Thanks
Thanks
Mine went in and game out just as bad after the recall work.
What I found was that there was a crap load of air in there. I back bleed it by pumping the clutch lever and then holding it until I no longer saw any bubbles, and repeated this many many times, it took 30+ minutes. AND I evacuated the old fluid as I was doing it cause the old fluid keep turning cloudy with whatever it was.
I know you can bleed it and that what needs to be done,, I did not want to deal with and the boys at the shop obviously did not do it correctly either.
NO problems since I did 3K ago
Just know one or two pumps is no going to get the air out, 100+ will
Thanks.
Thanks.
Your located in CUBA?
How did you get the snow down there?
