2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Q for all the FULL SYNTHETIC oil users....
Old 06-17-2018, 02:35 PM
zoozoo's Avatar
zoozoo
zoozoo is online now
Received 29,651 Likes on 8,087 Posts
Originally Posted by Erik Lundberg
I change oil as according to manual.
5000 miles engine. Red Line 20W60.
10000 miles primary. Red Line MTL.
20000 miles transmission. Red Line Heavy ShockProof.
These intervals are for dino oil so with a good synthetic oil it would probably not be an issue to extend the intervals. Especially if the bike is used for long trips in dry conditions and stored in a warm garage. But itīs better to have good margins.
Except I use Moble 1 20W50 in the engine.
  #32
Old 06-18-2018, 01:48 AM
cowboydoc's Avatar
cowboydoc
cowboydoc is offline
Received 1,089 Likes on 452 Posts
I follow the manual for intervals. Engine 5k, Primary 10k, Transmission 20k. Redline for Primary and Transmission. I got a good deal on some Syn3 from a guy that sold his bikes so have been using that for the engine.
  #33
Old 06-18-2018, 02:17 AM
cweiss's Avatar
cweiss
cweiss is offline
Every 5K I do a 3 hole change all Amsoil.
  #34
Old 06-18-2018, 06:24 AM
lyork's Avatar
lyork
lyork is offline
Once a year at storage time unless I go over 7000 miles
  #35
Old 06-18-2018, 06:36 AM
santajim's Avatar
santajim
santajim is offline
5k all three holes Red line plus spark plugs, just me being ****.
  #36
Old 06-18-2018, 11:12 AM
Mertoid's Avatar
Mertoid
Mertoid is offline
5k miles, Mobil 1 20w50 for 95k miles so far on a 2011 Street Glide
Bafflingbs (06-24-2018)
  #37
Old 06-18-2018, 12:00 PM
joeschmo's Avatar
joeschmo
joeschmo is offline
6th Gear
I can’t speak for the touring/big twins, but with my sportster I had used Syn3 for the engine and Forumla + in the primary/transmission. Seemed to work well.
  #38
Old 06-18-2018, 04:07 PM
todd-67's Avatar
todd-67
todd-67 is offline
Received 3,405 Likes on 1,593 Posts
Originally Posted by 1Canuck
OK, just saying, I have those rocker lockers installed and no valve train noise. Carry on
they are a good product for a lot of people but in my case (big bore with heads) they didn't work. The heavy oil works better than 20/50 in those cases. I run straight 50wt dino in my king but and amsoil in the glide. Both get changed at 5k.
  #39
Old 06-18-2018, 04:12 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
SYN in the engine, every 5k, SYN in the primary and trans at 10K I use Spectro oil
  #40
Old 06-18-2018, 04:23 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,604 Likes on 3,849 Posts
If it is in warranty, need to do what manual says. Out of warrant, here is an indication what going 10-12K which is what I did on a new car changing once a year on 05-20 Mobile 1. Mostly around town. The link timing chain was still dead on and the valve adjustment was maybe .001 off at 110K. Know it's a car but my guess is probably close to what most do on bikes unless you really run where it is really hot. Note that the timing chain is a link chain. However, the guides are huge and run almost length of chain with one being tensioner and one a guide and a top one for some reason..my guess is if something were to brake to keep chain from hitting valve cover.
Can remember years ago replacing oil ever 4 months. At 110 K, GM 350 Pontiac motor had a stuck hydraulic lifter. Tore it down an there was .005 cylinder wear.
jammerx (06-18-2018)
Quick Reply: Q for all the FULL SYNTHETIC oil users....
