Is it possible to remove the communication plug
Is it possible to remove the communication plug on the gas tank bib and replace it with a USB plug? I will never use the communications system.
Anything is possible. I don't know of any after market part to put a USB connector there however, you'd likely have to fabricate something.
USB to do what? Interface with radio? charge cell phone?
Couldn't you put a non-communication tank bib on there? JP Cycles has something that may work as well.
http://www.jpcycles.com/motorcycle-p...Ntk=All&Nao=24 |
huh, who would've thunk one would be reading all of the above lingo on a Harley forum? ...just sayin.
Originally Posted by Buckinfitch
(Post 13044060)
Yes, that panel is stuck on with double stick tape. Carefully pry it off and you can remove the ICS Jack. There's plenty of room under there to stow it. You could install something like this..
http://www.boatersland.com/polusb-pm.html I didn't ck the dimension on this particular one, but I like the idea. This one is nice because it's designed for marine application and has the cover. Personally I don't use comm either and I think that whole panel is butt ugly. I removed it, fabbed a contoured lexan panel, and color matched it. It looks nice and clean, and it's easy enough to restore to stock if need be. Don't have a picture handy. |
Originally Posted by jetfixer62
(Post 13045760)
I'll never use the comm. port either. For me, the fairing panel is better suited for sunglasses rather then my phlash drive. I've been thinking about removing the comm. port from the bib, adding a USB port to the bib, remove the USB port from the fairing, leave it in the fairing and run the bib USB to it. |
(Post 13045760)
http://www.boatersland.com/polusb-pm.html I didn't ck the dimension on this particular one, but I like the idea. This one is nice because it's designed for marine application and has the cover. Personally I don't use comm either and I think that whole panel is butt ugly. I removed it, fabbed a contoured lexan panel, and color matched it. It looks nice and clean, and it's easy enough to restore to stock if need be. Don't have a picture handy. didn't know it was taped down. |
Originally Posted by davessworks
(Post 13044112)
yeah - really not seeing your point here.
© 2024 MH Sub I, LLC dba Internet Brands
