OEM Heated Grip Install - 14 Ultra Classic
For those of you that have installed the OEM (black rubber) heated grip kit like those on the LTD, did you find it necessary to remove the bars or leave them in place? Due to other projects the outer fairing, windscreen, front wheel and forks are already off the bike.
The biggest PITA is getting the TBW unplugged so you can pull the guts out.
If you can find it behind the faring then your the man! |
Originally Posted by Just Me
(Post 14498483)
If you can find it behind the faring then your the man! No need to mess with the throttle side. |
Originally Posted by J929626
(Post 14498576)
(Post 14501838)
I suppose not if you only want a warm left hand.:icon_dunce:
I have heard the wiring connection under the fairing can be a bit difficult to find. Does anyone have detail on where it is located or better yet a pic?
On my 15 ultra standing in front of the bike!!! Assuming you have the fairing off, imagine where the left spot light,, right side if your looking at it from the front!! clutch side!!, would be look to the left just a little and it should be hanging there, I cant remember what color the connector is buts its there.
Originally Posted by wrenchguy24
(Post 14502562)
https://cimg5.ibsrv.net/gimg/www.hdf...991f300e2f.jpg |
That looks like it. Should be two wire +12 and ground.
© 2024 MH Sub I, LLC dba Internet Brands
