Excessive Vibration
I just traded my 2013 FLTRU for a 2016 FLTRU. The vibrations were excessive. Leaving from the dealership, I thought I was on my old 2002 ridged mount Sportster. The faster I went, the worse the vibrations got. I took it back to two different dealers and they both said they couldn't find anything wrong and the vibration was normal. At the second dealer I had them balance the front tire, and that helped some.
After researching the issue on the web, I found that this seemed to be a problem on the 103 HO engines. No one complaining about vibration had anything but the HO engine. These have different CAMs due to the water cooled heads. There were some who had found torque values off on the motor mounts. I took the bike to a third dealer and had them check the torque on the lower and upper motor mounts, and all exhaust and shock absorber connections to the frame. They found them all to need tightening.
After this the vibration was considerably reduced, but still not as smooth as my 2013 was.
I actually dumped my 2014 Limited because unlike every Twincam I've owned, it vibrated so much it felt like I was holding on to and riding a weed wacker every time I rode it.
Tried like hell to have it fixed, went though a bunch of effort on my own, and finally just gave up an traded it. Just a crappy deal.
This matter of motor mount torque actually helped me decide not to return to the dealer shop for anything.
I picked up my 2016 FLHTCU in January of last year. At 1000 miles I took the bike in to let them do the 1000 mile service, and then for me to check out the bike to see how they did.
One thing they're SUPPOSED to do is to check the torque on the front motor mount bracket. When I checked mine, the two bolts and nuts on the bracket were way loose. Not just a little under torque. LOOSE. As well, the three fasteners on the right side mount.
I knew then that I would not be going back to that dealer shop for anything that involved one of their mechanics putting wrench on my bike. Apparently all they did was pressure wash the bike, and even that was a complete botch job. They put more dirt on, and got the dirt deep into the inner crevices. All that for only $400.
I was talking about both motor mounts. The one (actually 2, one on each side) at the front bottom and the one at top.
In my research, I have not heard of this problem with the non water (head) cooled bikes. The vibration problem seems to be exclusive to the 103 HO engines. These engines have a different cam. The CAM must be causing the problem.
Having the dealer specifically check all the torques on any thing that touches the engine or frame greatly reduced the problem. The vibration is still there, but tolerable. If it gets worse, or I can't stand it I will have the non water cooled CAM installed.
