FXSB Breakout Upgrade DIY: Fork Suspension / Tires / Brake -Part numbers, tools, tips
#123
Nope, tried that,won't work. They end up hitting the fuel tank when turning. I've got another thread going trying to find out where guys are getting inverted mirrors to fit a Breakout
#125
Received 1,934 Likes
It wouldn't surprise me if there's been a bit of a run on the 39mm units. Owing to some very positive commentary on the "Everything Breakout" thread I'd bet a lot of BO owners are buying em. "Every" BO owner should be buying em.
#127
Remember, if you go the "Richor" route you won't need to drill your damper tubes. Just change to 5 wt fork oil. This is easier and reversible if you don't like the result. Reversible is an illusory benefit, however, because there's no effing way you won't like the result.
#128
Did mine a week ago and so far very impressed with the mod, no more spongy front end. If anyone is thinking about doing this mod it is very simple if you have the proper tools and one of your kids to hold the forks. I had problems finding a 35mm socket so I used I believe a 1 3/8 which is more common. Thanks again OP.
#129
#130
hi there guys i have breakout 2015 want change the stock exhausts confused between two v&h twin slash 3" and screaming eagle slip ons,i am looking for sound and power ,but not ridiculous sound but better than stock exhausts,i already fitted SE bilet air filter,one more thing i wanna know if i go for v&H do i need v&h fuel pack too or its ok without that do let me know thanks guys
