Softail air suspension
So, in summary, there is a check valve between the pressurized air line and the feed solenoid, correct? Are the solenoids serviceable? If so, please elaborate. Also, who manufactures the pump? With my experience catastrophic air-ride failures are primarily caused due to failed solenoid or pumps. Unexpected plumbing/fitting issues can generally be fixed on the side of the road, but solenoid or pump failures will commonly put you in a trailer. I'm considering a system for my FB, but it needs to be reliable and fully serviceable (namely because I don't want to hear my wife bitch). As such, can you please forward me a plumbing and wiring diagram? Drew - I belieave you sell Shotgun, assuming I'm happy with the diagram and response I will be in touch.
Thanks,
Chris
Thanks,
Chris
Drew
sincitychoppa
12-31-2018 05:47 PM
rkeith01
05-01-2008 08:14 PM
2011, air, davidson, forums, frame, harley, hd, legend, problems, progressive, sale, shocks, shovelhead, softail, suspension
