my dyna got an air ride today
well figured this will get a more appreciative audience here then i nthe dyna section
well been slowly piecing together my Airride set up finally got it finished today
2001 fxd,
Compressor- Viair 98C
ASCO 12v solenoid valve for dumping.
3 position toggle next to the horn
2001 fxd,
I don't know what your goal was but if a better ride & a hell of a lot better handling were them then you missed the boat. I just got rid of the air rear schocks & replaced them with JRI coil/overs & am amazed with the difference in ride quality & handling. Worth every damn penny but don't deal with Howard call Tim at JRI directly.
ym goal was an upgrade over both the stock shocks and the OEM touring "air assisted" shocks. both handlign up to and above 145kph has improved greatly and comfort is worlds better, with the added ability to tailor the needs for added or decreased weight with the push fo a button. im quite happy with the set up. and all in im under $300 installed for my needs its an ideal set-up.
Here is another option
A
i know your products and service are TOP NOTCH jd, and i am lookign forward to seeign the dyna/bagger model out in the market. unfortunatly my budget doesnt allow for the qulaity products and service you produce at the moment and so i am stuck i nthe DIY relm for now. keep me informed as to the model roll out for dyna/bagger line up though as air ride is reletivly new around here *im the only biek with anything clsoe to full air ride in the tri-county area and have lots of interest in it from regular clients* would love to be able to have the option to offer your products and high level of service to the clients i get that arnt lookign for a low cost alternative to air ride like mine.
NSCoyote
10-06-2015 08:49 PM
