Test: PPI Phantom 4.900 4-channel Class D amp (900W claimed)
Sponsered by Haze324 - thanks bud (amp on its way back to you as well as your "faulty" RZ4; nothing wrong with it, I had it blasting for 20+ minutes with no issues).
the results are in:
details in the PDF, here the highlights:
Bike Running and revving a little bit:
~220Watts RMS at 2 ohm (Vac ~21V)
~125Watts RMS at 4 ohm (Vac ~22.4V)
FM: this unit I tested did NOT lose any stations (tested with stock HD antenna)
Not running hot on temp!
THIS IS A BEAST - Now I know my JBL P963 6x9 need POWER to get even better... this amp WILL blow up "any" 6.5" speaker, like my Polks so be careful... turn the gains down if running 1 on each channel...
Sound: "neutral" on lower volumes, not enough low/low mid at high volume when running flat EQ. simple adjustment on HU or on the extensive options on the amp itself (LPF/HPF/BPF options available).
For a mere 210 bucks you get PLENTY of power.
DOES NOT FIT IN FAIRING - PERIOD (yeah yeah: i had to try...). luckily for Haze, otherwise I would have kept is and buy a new one for him....
note: I ran over 10AWG power line with 25A fuse - no problem...
https://www.dropbox.com/s/73oi8stsaz...20amp.pdf?dl=0
the results are in:
Last edited by AAWAV; 01-16-2015 at 09:07 PM. Reason: incorrect Vac at 4 ohm... too much beer LOL
the results are in:
~125Watts RMS at 4 ohm (Vac ~15.8V)
the results are in:
you'll be throwing (clean) 125 watts to the Pioneers (4 ohm) so should be fine... no LPF or HPF there (believe rear only has LPF, cannot recall and amp is already back at USPS...
and.... strap bike down, otherwise it will jump off the driveway due to the Pioneers thumping
OOOOPPPPPSSS double post
2 tips: turn gain back on the kappa's (amp is too much for them IMO), put hpf on the kappa's - play a bit with the freq. there ~80-100 hz. do NOT push the freq x10 buttons.
LMAO!! I got some straps if you need em. . . .
