Time to step-up the power to my system - Seeking your Input.
Never had pods so not mich help there. I know the Polk mm 651 used to be a fav of ganns. I would focus om both pods and consider speaker lids. If the aw are still not loud enough I would consider jumping to the pro audio bandwagon and add some rear to retain some low end. Its all about system balance but still keeping the front stage primary focus of volume.
$300.00?? Who did you get that hell of a deal from, lol.....
WTR, keep checking the classified buddy. Folks are getting rid of stuff daily at great prices.
I'm with bunker on his choice or the arc 600.4.
You know with your hearing loss a you already have, uh I have a prediction that if you keep using the ante you may be losing more.....
Imo you are wasting time and money to increase power in the wrong area. 150 watts is good for that set. If BAL comes and says run 200 then so be it , but it would have been suggested from the beginning. T is plenty happy with his at 150. Until you accept the rear stage or lowers need added the extra watts you will put there will have a negligible difference. Rule of thumb is double the power to gain 3db in volume.
WTR: before I purchased another amp I would bump the JL up to 150-160 watts.
As far as tourpak speakers go you don't know what you're missing! If you can fit another JL amp under the faring and a good pair of speakers you will be able to hear them at any speed. I currently have the BT amp and Milli pros back there. They will need the V-Twin adapters thou. From what I hear the Focal 165 KRC work very well if not better. Another option are the Hertz HCX 165's with 1/2" spacers. SF has a pair for sale in the classifieds.
Bertk - I've already got the MHX gains bumped up to 25.3 volts, so it's producing 160 watts + or -.
It may indeed be time to consider upgrading the rear stage, instead of just throwing more power at the front speakers. I'll need to see if another MHX will fit inside the fairing. If it will, I'll definitely need another BT355, in addition to rear speakers and possibly adapters to fit them in the pods.
What's the general consensus of splicing & dicing the wiring harness in the fairing for access to the rear speaker wires versus getting the BT Break-out Harness? I really hate cutting factory wires.
I guess that another option (I can't believe I'm saying this) would be to mount the amp & BT355 in the tourpack.
Code:
Pin Color Speaker K1 LBE RR + K2 LBE/BK RR - J1 LBE/O LR + H1 BE/GY LR -
Cut each of the wires above.
Solder a 16ga length of wire to each one of the cut wires (color coded for + & -) long enough to reach the amp inputs or Universal Line Levelers in this case and to the speaker outputs on the amp.
Apply shrink to each connection.
Apply shrink to each pair of wires and label them.
Reapply the wrap and tape the end.
The four wires coming from the plug on the harness will connect to the Universal LL.
The other four wires will connect to the speaker outputs on the amp.
WestTexasRanger (03-10-2017)
If u gonna spend any money on an amp u might as well get a 4 channel for the tray and bridge it then side mount the MHX 280 and use that for the rears. Plenty of amps avail for the tray from the $100 Soundstream to the DD D4 up to the $300 JL MX 500/4.
Then get simple coax for the rear depending what ur ears and wallet want. The AD 2100 might be a good play. Motos? Polls? BT?
This will get u the 200w to the AWs and 150w for the TP pods.
T.
T.
There is a thread somewhere where the Fosgate guy explains the difference between the TM and T and some kind of shielding in the TM version.
Took another 2 hour ride yesterday to keep breaking in my AW6.5/BT30s and AD CX62s in the rear, being pushed by the Bt4180. Let me tell you, this is starting to sound better and better as they break in. I do not find any harshness in the BT30s, so I think you will like those.
For the rear, those AD CXs are fantastic! Loud! They perfectly compliment the AWs and fill out the sound stage. Though the AWs are the primary source when flying down 80mph, I have toggled between just the fronts and both front/rear and, call me crazy, but I can hear a difference when moving down the road. Parked, no question the AW CXs in the rear add to the sound and make it really shine.
On power, I was thinking just the same thing last night. At one point I had the volume maxed out on the Boom 6.5 and it seemed the speakers all wanted and could have taken more power. But, I am going to leave it as is for a while.
