Access to rear speakers
The other alternative is to run extra speaker wire from the rear back to the front and then back but that is a PITA
If you're up for mounting a small amp in the tour pak, you can use the existing wires in the pods to feed the amp. Then just run new wires into the pods to feed the speakers.
You will need to run pos and neg wires though to feed the amp. Just use disconnects so you can remove the tour pak.
XTsHOG
Audio Systems
06-08-2017 08:43 AM
Suedekustom
01-21-2012 06:39 AM
SOLOLUCKY
10-14-2009 08:40 PM
