Which PA Speaker: PRV vs MMats vs. DD Audio vs Hertz
Originally Posted by Bunker
I'm SO glad you finally posted this, those Tempesta's are one of the best PA speakers for Tour Pak pods
I was pretty damn impressed with these little beauties.
You do need a solid front stage though, I wouldn't say they are great by themselves but in the Tour Pak with the MMats up front, I was very happy with the Temp's. MUCH better than the 602's they replaced and I'm a 602 fanboi lol
Again, ALL of these speakers sound like ***** as stand alone speakers so before u jump in the deep end, make sure u have an extremely balanced system laid out or u will regret it. If u don't believe me, fade to any speaker on your sled, jam ur favorite song and play it crossed to not let any lows in under 95 and no highs above 6500.
T.
That's awesome to see. When I spoke with the owner of MMats last month he mentioned his meeting with CAMTECH. That's good to see that CAMTECH is on board with MMats as they are a big player in custom baggers.
Finally got my Beyma Pro6WND speakers installed and tuned up. After a LOT of help from Tailwind and advice from Pdevore. I took them out for a ride! WOW! They sound great! Clean Crisp and at 70+ they didnt miss a beat! The Pro6WND are the 4ohm version of the Pro6GND 8ohm speakers and are hard to find but, damn if they dont sound great! Adding DD AW6.5s and AT28 tweets to the mix but the efficiency of these Beymas are fantastic 97db and they scream!
When I installed my lowers, I initially went with the PRV 6MB-200-4 mid bass woofers and they did sound good. https://www.parts-express.com/prv-au...-ohm--294-2703
But, being the frugal guy I am, I tried the Orion CM65 midrange speakers and they are a nice improvement. Can't be the $55 cost either http://www.orioncaraudio.com/cm-series/741--cm65.html
Haze actually introduced me to the PRV's a couple years back when we called em area 51 speakers and I've probably installed 10 sets of PRO audio speakers in my bike since then. Everything from eminence to crescendo's.
PRV are the best of the best. Can't beat em if properly tuned with the right amp. I'm presently running PRV in my upper, lower and saddle bag locations and I have to say they are THE BEST PRO audio speaker I've come across and trust me I've come across quite a few! You guys with the 13 and down bikes throw a set of DD VOB3 horns in your gauge holes and a set of PRV NEO's in the upper and lower fairing and you'll NEVER change speakers in those locations again. Take it to the bank.
You want horns with these speakers brother. The PRV are so darn loud it will drown out a dome tweeter. Like Gann mentioned I've been using these speakers for a few years now and am now luckily a distributor for them. I've tried them with many different combos.....you need a horn.
The following 2 users liked this post by BaggerAudioLab:
bdrummer0413 (09-11-2018),
Markeje (07-05-2017)
