Running 2 4ch amps ?
Originally Posted by ew25950
If you have a dedicated amp for front and bags, what's the big need to be able to fade them? Wouldn't you just set the gains appropriately if the front or back was overpowering?
There are many trusted guys here, but I'd start with one LL and 2 simple Y adapter's assuming you can fit all that in the Road Glide nose. That's what I did and it's working great for me (Fairing though). I have a JL 280/4 and a Cerwin B52 on one LL in the fairing. You can always add another LL if you really need to later.
T.
Originally Posted by Houston_t
I have a Road Glide so no pod eliminators (unless that's something new) almost considering getting rid of the factory head unit and going aftermarket, the ONLY thing i like about the factory unit is the fact that navigation shows dirt roads, other than that i guess i could really care less about the boom system.
I think what u select will be based on what will fit ur ride. I don't do amps in bags or pack thus I huge factor in my product selections is size for under the hood install.
T.
I went with 1 focal sport, it just Barely fit, but I got in in right on top,of the headlight, for anything to fit behind it, it will need to be a square amp, I know that’s out of your budget, but it flat rocks! And no need for 2 amps, there was one in the classified for 600 I think. Good Luck!
I cannot remember the dimensions of the area or what amps will fit or you can mount one on the headlight like Mike300 did.. Maybe someone with a Rushmore shark nose can chime
Dragonfly cycle concepts sells a mount that they swear will mount the Focal Sport under the radio on a RG. I have the mount and amp but bike still at the dealer so can't speak to it first hand yet. The biketronics amps easily fit under the radio with their mount. Their 4 channel amps are 5x7.
Thanks
