Sony xav-ax100/CV B52/kappas installed
Parts removed
It begins!
Routing power and ground
Weather tight connector for speaker wires coming from amp.
Amp mounted
Power, ground, and remote hooked up
Closing up
Last minute details
Almost done
Road test!
Just wanted to say thank you for the help with getting my RGS to sound a lot better. Y’all rock!
Take a look at the pics. Ask questions if you want. I made my brackets out of aluminum flat stock. They are held up by the radio’s stock bolts. I just ran them up from the bottom and used red lock tight on them and put nuts on the them to hold the new stereo down. The remote gain adjustment: I adjusted it, marked its adjustment with paint, taped over it to secure it and finally zip tied it to the harness under the fairing as I see no need to have it accessible.
