Bad antenna, coax or mast?
Long story short, outer fairing is off and these last few months the radio stations that used to come in clear, no longer come in at all. So I have an old Chevy truck replacement antenna hanging in the shop, plug it in and all the stations come in again... So question is, is there a typical spot I would have pinched it or that they go bad? Its an 08 ultra with some audio upgrades but has worked for years the way it is, and this is a new problem. I did look at the antenna coax and connectors and nothing is apparent, but I could be missing something too. Any input is greatly appreciated. Also hello to all the audio guys, I know i kinda disappeared, but went from a computer job to an operator (heavy equipment) job. So much for long story SHORT.
Kris
Kris
Good to see you around again BP.
under the left side panel near the fuse box is an antenna connection. Check from center tip that plugs into radio to center of that connection for continuity. You should have a relatively low impedance reading between the 2 points. Also check the outer shield the same way. Also check and make sure you have NO continuity between center pin at radio and outer shield at connection under side panel.
Kris
Kris
FYI pouring rain and 35 degrees right now, might make most of ya feel a little better about your weather....
Did a little digging around under the side cover around fuse box and see where the coax goes from rear to front behind the fuse box and didn't find the connector. Is it easier to see or get at from the battery side (inside) or the outside near the fusebox? Not afraid to open it up, but thought ya might be able to save me tear down time. Thanks again for any input.
Kris
Kris
the connector may be in the battery compartment. I see them in different places on different baggers.
well if it makes you feel any better, it's 80 here and blue skies.
you might also check the intermediate coax connection under the seat ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
