Super E turning
#31
I was at 2.5 turns out and she still kept popping.
Always worth a second look.
#32
Is there any difference if the accelerator pump is turned off or wide open when blipping the motor?
#33
Yes the lag definitely decreases when seeing more fuel to the spray. My assumption that .28 is to small for my setup and that .295 is in line with what everyone else was mentioning.
Stiggy (03-04-2018)
#34
So I got to take the bike out on a ride and I did notice slight hesitation, but that could also be due to too much free play at the throttle (didn't have time to adjust) 😜 Power seemed great when under acceleration. I also took note that I did not once carb fart. What seemed like a major carb fart issue only happened with quick blips of the throttle while not under load.
#35
I'm having the same problem with mine. My engine is a stage 2 evo, .031 int, 68 main and a 130 air bleed. Was out riding today and got it good and hot, the mixture screw is 1.5 or so turns out and I got my accel pump screw 2 1/4 turns. When I blip the throttle it just doesn't have very good response. No decel backfiring, just a tiny bit of popping. Sitting here scratching my head.
#36
Okay, finally a decent update. I took the time to read the S&S manual and redid everything from the baseline of:
intermediate jet: .295
Main jet: .70
I was getting carb popping at around the 1.5 turns out from lightly seated but not anything pass that. Changed to:
intermediate jet: .31
Main jet: .70
So I rode around testing with accelerator pump off and got no popping down to about 1 turn, from which now I run at 1.25 turns out from lightly seated.
My question for all you carb gurus, what color should I be getting on the base ring when testing for jetting on the intermediate circuit? Once I figured out the idle mixture I then:
I'm getting a very light tan around the base ring.
Main jet: .70
Main jet: .70
#37
Few quick dyno runs would have your bike in good shape, in short order.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
#38
With today's fuels it really is a little hard to determine the burn by looking at the plugs.. if you don't have a Wego exhaust gas analyzer them a Dyno would set it straight. The days of looking at the plugs are long gone along with leaded fuel...
#40
