Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
SS Super E Carb
Old 03-10-2018, 01:27 PM
eek88dj's Avatar
eek88dj
eek88dj is offline
Default SS Super E Carb
I have a 1340 on 88 Softail FXSTC with a new super E carb i got the pilot jet 231 main at 70. I'm trying adjust the snap of throttle it fall on it face or back fires. It idles fine I turn the pilot in it stumbles then turn it back out it stumbles so i have it adjusted in the middle . Then I try adjusting accelerator screw for snapping of throttle it won't do it , just backfires , any help woukd be appreciated. Is my jetting ok or am off on my jets?
Old 03-10-2018, 01:34 PM
Bubby's Avatar
Bubby
Bubby is offline
I would check for air leaks and the condition of the plugs before changing anything else. A fresh set of plugs will tell you alot providing you can take it for a ride.
Old 03-10-2018, 01:42 PM
eek88dj's Avatar
eek88dj
eek88dj is offline
the plug are black I clean them to. Black again.
Old 03-10-2018, 02:08 PM
eek88dj's Avatar
eek88dj
eek88dj is offline
Is my jetting ok on a 1340 evo.
Old 03-10-2018, 08:39 PM
kantdo55's Avatar
kantdo55
kantdo55 is offline
S & S has a tuning guide on their website. You can also find a tuning guide at Nightrider.com.
Old 03-11-2018, 09:23 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,810 Likes on 3,315 Posts
On a stock 1340, .028 intermediate .070 main with the Idle mixture screw at 1 1/2 turns out from lightly seated and the accelerator pump at 2 turns out from bottom. Make sure your idle is around 950 with the proper idle mixture screw setting... That should be very close to what that motor needs..... Timing could also affect idle and acceleration...
Old 03-11-2018, 11:29 AM
eek88dj's Avatar
eek88dj
eek88dj is offline
Thank you!
Old 03-12-2018, 12:57 PM
frankjc's Avatar
frankjc
frankjc is offline
I had similar problems with my sportster when it had an S&S carb. It ended up being due to electrical problems.
Old 04-04-2018, 06:04 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
What exhaust?
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 04-06-2018, 10:52 PM
craigthecarpenter's Avatar
craigthecarpenter
craigthecarpenter is offline
I was having problems with my 883 sportster and a S&S Super E. It turned out that I had an air leak between the intake and the heads. I replaced a set of black seals with the blue ones pictured. It made all the difference.
Before changing the seals the bike would carb fart and "hunt" when traveling at a steady speed.
Craig
Last edited by craigthecarpenter; 04-06-2018 at 10:54 PM. Reason: added some more info.
Quick Reply: SS Super E Carb
