Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Velocity stack rejetting
Old 12-07-2018, 10:38 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Wink
I had a year old Velocette Thruxton, which came new with an inlet stack:
Old 12-08-2018, 09:54 AM
bustert's Avatar
bustert
bustert is offline
only one word to describe it "SWEET"
although by today's standards where style trumps practicality the older machines had an appeal.
the indian line of motorcycle (original) were interesting. i had a vertical twin that i inherited but was offered too much money for the parts value and i let it go. now if it were the inline 4, would probably still have it. over the years, i had over 40 diff machines. usually got them as seized or wrecks and rebuilt them. my father was a naval machinist so parts were not an issue.
the across the pond machines all had style.
Old 12-08-2018, 11:50 AM
grbrown's Avatar
grbrown
grbrown is offline
Red face
Living across the pond, we had tons of wartime Harleys and some Indians left behind, when the US forces returned home in the '40s. I had a 500cc Indian twin for a while, a non-runner, but the cost of replacement parts to rebuild the engine, in the late '60s early '70s, was eye-watering over here, so I let that go eventually.
Old 12-09-2018, 10:00 AM
bustert's Avatar
bustert
bustert is offline
this was an indian scout 249 which was 440cc. it resembled brittish machines and was way advanced over usa competition. this had twin ignition systems and gear shift indicator. i had the complete machine including the original battery. it was in my uncle's barn in illinois for decades, he quit riding when a truck passed too close with west coast mirrors and put a metal plate in his head, doctors forbade him to ride.
in its heyday would have been like this
http://www.themotorcyclemuseum.com/i...Scout-1080.jpg
Old 12-09-2018, 03:08 PM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
I've never seen a real one of those 249s in the metal, but they do look odd, in as much as the primary is on the right, whereas so many brands have it on the left. Good looking bikes:
Old 12-13-2018, 12:33 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Originally Posted by Kingglide549
What about stacks inside a filter?
will that smoooth it out?
That works.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 12-13-2018, 01:08 PM
bustert's Avatar
bustert
bustert is offline
in times past, bells were added to air cleaners, VW and MG as examples. however, this only equated to only 1>2 hp gains that could be proven. also in the past, funnels were sold to mount on the bottom of air cleaners, i even ran one. a stack inside of an air cleaner can be counter-productive since it adds a restriction to the volume of the air cleaner. they make a thing that is called a pod, if i remember correctly which mounts to the carb throat and adds a radius leading to the venturi opening but is only around 1" in protrusion. a big issue with a stack in a filter is the way the air flows through the media. will it work, hummmm, good question??? it definitely would be a bear to tune if you are looking for that. another issues as the media clogs, so does cause and effect.
if setup correctly, a butterfly cleaner in a ram mode probably would be better if the shutters were timed right. if not, the ram air could upset carb function as the are not a positive pressure devise as a norm.
i do not know if hd tunes the cleaner to the system but other makes have a science of it. look at the rice super slab machines, everything matches up for max performance.
i was wrong, not called a pod. the jpeg below is what i was referring to.
Old 12-14-2018, 06:00 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,811 Likes on 3,315 Posts
Scott did prove on the dyno with my 98 Evo that a velocity stack can make a difference. IIRC it was 2-3 hp... The S$S carbs work on the same theory, increased velocity.. Instead of running a velocity stack a 1" spacer gave close to the same results.....
Old 12-14-2018, 08:57 PM
bustert's Avatar
bustert
bustert is offline
very true very true
the extra plenum volume holds the extremely well mixed fuel aided by the reversion or reverse pulse wave, same as the stack, burning twigs vs logs, more power.
Trueno
09-26-2016 01:54 AM
Locoles
General Topics/Tech Tips
12-01-2014 02:57 PM
D_gyver
EVO
139
11-13-2014 06:19 PM
Troy D
Canada
02-12-2013 06:05 AM
nh-dwg
EVO
01-19-2012 04:31 PM
Quick Reply: Velocity stack rejetting
