I used Meguiar's black restore stuff...works great!
I've been using it for the past few years on both of our vehicle's , seems to hold up really well during the summers months , but during the winter , when the salt on the road gets put down , I find that you have to apply another coat after you wash .
The salt will stain / fade the plastics , but not nearly as bad as it was before you applied it the first time .
A little goes a long way , one bottle usually lasts me a couple of years .
Last years.
https://www.carpro-us.com/wheels-tri...-coating-30ml/
is the trim faded and trashed? If so, need to approach a different way
Received 47,972 Likes
A word of warning ... Sounds like Dlux is the winner, however be sure that in the event you are going to do paint work be sure to extra diligent with your prep work ... Thoroughly clean with soap and water and then with wax and grease remover BEFORE any prep work is started ... SIlica / silicone can and will wreak havoc with new paint application
Rusty Springs (12-24-2023)
