What did you do to your Dyna today?
Old 04-29-2017, 11:22 PM
JoshFXDL's Avatar
JoshFXDL
JoshFXDL is offline
Originally Posted by e11charlie
Just finished my first auto tune session today. They of course don't make a map for firebrands so I just used the base map for V&H short shots. It ran fine with the base map but just trying to dial it in. But holy sweet baby jesus these pipes are ****ing loud as hell. Nice low rumble but getting on the throttle is deafening. Gonna have to wear ear plugs while riding or find some sort of baffle insert that will work with these pipes.
Which firebrand pipe do you have? I have the loose cannon slip on and it was only slightly louder than stock.
  #5742
Old 04-30-2017, 01:01 AM
johneville's Avatar
johneville
johneville is offline
Stage IV
Default Hardcase bolt lock-r and Dunlop American elite tires
Bolt lock-r was an easy upgrade. Came off commander 2s and got in Dunlop American Elite...
  #5743
Old 04-30-2017, 03:38 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
Just throwing this out there; you should always be wearing ear plugs, no matter what pipes you run or what type of helmet you're wearing. It's not the pipes that will damage your hearing, it's the wind noise; over time the wind noise will destroy your hearing. A good set of ear plugs blocking out the wind will let you actually enjoy those new pipes; and let you keep your hearing
http://www.hearingtestlabs.com/motorcycle.htm
Originally Posted by TBT3
Ordered some red spark plug wires. Just something to add a little color. I like the way it looks for now so time will tell if I keep them on. One things for sure, I need to relocate the horn. That big *** chrome cowbell just looks really out of place.
I like those old cowbells But the plasti-dip is a good idea if you want to cut down on the chrome look. One way you could clean up the look of the cowbell and plug wires a bit more is to re-route the front cylinder plug wire. I used 10mm wires and sleeved the plug wire to run it behind the horn bracket with 3/8" hose to protect the plug wire instead of running it over the top of the bracket. Routed that way you can also have the front cylinder plug end at a right angle to the head, just like the rear is.
Best image I've got at 4:35 AM, but you can see how the front is run now, looks much cleaner to me. If you need a better image I'll grab you one later today...
  #5744
Old 04-30-2017, 05:33 AM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
Ordered Vance and Hines Pro Pipe for my 05 Supposed to be here Monday .. Pictures will come after gets here ..
  #5745
Old 04-30-2017, 07:04 AM
TBT3's Avatar
TBT3
TBT3 is offline
My issue with the cowbell is that I've got this big beautiful HD V-Twin engine and the cowbell is covering it up. It's not that it's chrome and I'm not looking to go the blacked-out route. (Not knocking the blacked-out look. Some badass bikes out there like that. Just not what I want.) It's more the placement and blocking the look of the engine. Be cool to see more of the V on that side.
I like the coil relocation where it moves to the spot where the horn is. That's ultimately what I'd like to do. Either a DIY project or buying a kit from somewhere like DK Customs. But for now this'll work. I did run it behind the bell bracket at first but I was worried about it rubbing up against the engine. The 3/8" hose is a good idea.
  #5746
Old 04-30-2017, 07:10 AM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
I had the same concern but I took it an additional step...
  #5747
Old 04-30-2017, 07:34 AM
TBT3's Avatar
TBT3
TBT3 is offline
Yes! That's what's I'm talking about. Looks awesome!
  #5748
Old 04-30-2017, 07:41 AM
TBT3's Avatar
TBT3
TBT3 is offline
So here's a noob question, but that t bracket that the horn is connected to and that connects to each side of the V and connects under the tank to the air filter - is that only there for the horn? Or is it serving additional support purpose?
  #5749
Old 04-30-2017, 08:01 AM
TinCupChalice
I'd leave that in place That's the engine mount bracket the top stabilizer link is mounted to. Take a peek under the tank and you'll see the stabilizer link tucked in up near the tank.
I do get what you're saying about wanting more of the engine visible; they are beautiful indeed
  #5750
Old 04-30-2017, 08:20 AM
TBT3's Avatar
TBT3
TBT3 is offline
cggorman, I was just reading through your build thread to see how you relocated the horn and coils, and I realized we aren't even on the same planet in regards to modifying our bikes. My man, you are literally designing and fabricating your own modifications. Incredible.
TinCupChalice (04-30-2017)
Quick Reply: What did you do to your Dyna today?
