Couple updates. Bag bracket/speedo blank
So figured out how to make my bags rigid and tight to the fender
I'll post pics after explanation.
So the quick disconnect option on the used set of bags I bought worked like poop. Not rigid, had movement on highway and overall just wasn't happy with it
So I removed the brace that's quick disconnect. Marked holes accordingly on a piece of thick *** flat stock metal from lowes
The good thing is these bags are thick fiberglasses backing so the bags themselves are super rigid
I drilled 4 holes into flat stock
2 holes to go where factory strut connections are to be and then an additional 2 in the middle so I can bolt the bags to them
I used 7/16th on my bags to brace connections with lockable nuts. I'll be swapping out to dzuz clamp bolts or touring saddle bag quick realease bolts soon
I then bolted the flat stock brace to the strut and used original saddlebag hardware and used washers to space the bags off the fender
Then I bolted through the bags into the middle holes of the new brace securing the bags and making them super duper rigid.
They have absolutely no flex and are very tight on the struts visually
If I want to remove them I open the bags and unscrew 2 7/16 nuts and the bags are off. Very easy on and off set up
All in all I spent $17 on flat stock and 2 cutting wheels
So much better than using aftermarket easy brackets or ghost brackets. Those aftermarket ones are very expensive and stick out very far
I will be shaping the braces to match the lines of rear strut and get them powdered black
Also I made a gauge blank for the speedo I relocated. I'm also powdering this the textured Mat black to match the console
It's a stainless circle cut and the bottom I used a circle cut also, then I cut off the edges of the circle keeping the center channel
I drilled holes and used a sandwich clamp style on the outer and inner console
First I went with a acorn but, but it stuck out to far so I went with s button head hex bolt. I want everything to get textured black so it blends in
I also need to clean up the circle and make it perfectly round
Cost was under $5 to make this so far
sdrawkcabssa
04-05-2017 09:08 AM
