New Low Rider S
Old 02-24-2018, 06:46 PM
waynestarnes23's Avatar
waynestarnes23
waynestarnes23 is offline
I have had an Ultracool Reefer Oil Cooler installed on my 2017 Lowrider S. Ever since it was installed my running lights will go out after going about 10 miles and my fuel gauge shows low range when I just filled up. Seems like when the dual fans kick on is when this happens. Has anybody else had an issue with this happening with their FXDLS?
  #2502
Old 02-24-2018, 06:58 PM
waynestarnes23
Default My 2017 Lowrider S 117 and Dyno results
CaptainAwesome (02-24-2018)
  #2503
Old 02-24-2018, 08:28 PM
gus4440's Avatar
gus4440
gus4440 is offline
No, but if you tapped power off the rear brake light switch like the instructions tell you that could be your problem. It's screwing with the can bus
waynestarnes23 (02-24-2018)
  #2504
Old 02-24-2018, 08:37 PM
waynestarnes23
How would I fix this issue then?
  #2505
Old 02-24-2018, 08:45 PM
waynestarnes23
What can I do to address this issue then?
  #2506
Old 02-25-2018, 02:45 AM
gus4440's Avatar
gus4440
gus4440 is offline
There is an accssary plug in the left side cover. HD sells an accessory adapter that plugs in to that. Tap your power off that.
HD electrical connection harness Kit number 72673-11
waynestarnes23 (03-11-2018)
  #2507
Old 03-03-2018, 05:09 PM
thisisagame24's Avatar
thisisagame24
thisisagame24 is offline
To all you guys who installed the bars on your LRS, was removing the tank necessary to get to all the connections or can I just pop that grommets out and get to them that way?
  #2508
Old 03-03-2018, 05:20 PM
rideon's Avatar
rideon
rideon is offline
Pop the grommets
  #2509
Old 03-03-2018, 05:42 PM
ndputnam's Avatar
ndputnam
ndputnam is offline
5th Gear
I just did my bars this past week and just slid the tank back which gave me plenty of space. GL
  #2510
Old 03-03-2018, 06:27 PM
rbdub474's Avatar
rbdub474
rbdub474 is offline
No need to mess with the tank. I put 10” risers and 3.5” rise bars on mine. Just pull the grommets and fish the slack out.
Quick Reply: New Low Rider S
