Chirping, rattling sound from my dyna is driving me loco
Old 05-13-2007, 10:57 AM
HD/SB/06's Avatar
HD/SB/06
HD/SB/06 is offline
Default RE: Chirping, rattling sound from my dyna is driving me loco
I had the problem last year. A nut came loose on the top motor mount and caused a squeaking noise.
Old 05-13-2007, 11:12 AM
Sharknose's Avatar
Sharknose
Sharknose is offline
ORIGINAL: rocklayer2
My road kings rear final drive belt started making a chirping noise about 100 miles before it broke.
Your description of "chirping" makes me agree that you should check your belt tension. I never had one fail, though.
Old 05-13-2007, 05:43 PM
DenimStreet's Avatar
DenimStreet
DenimStreet is offline
ORIGINAL: mudpuddle
Nowdays I use a stethascope. Way back when, I used a length of
tubing (fuel line, vac hose, garden hose, whatever was handy),
one end stuck in or near my ear, and the other end moves around
near likely then unlikely sources of the noise.
This can be done on a stationary, or, a moving vehicle or other machinery.
Mud, I'm sure that works, but it must look awfully funny when you ride down the road like that!
Old 05-13-2007, 05:54 PM
theoldguy's Avatar
theoldguy
theoldguy is offline
Had something like that on my '05 WG, I'd hear some chirp kind of sound when I'd pop the throttle or sometimes running down the road. Finally figured it out this afternoon, it was the back of the seat making that noise. Tightened it down a little more and its gone now.
Old 05-14-2007, 09:53 AM
MaineHD's Avatar
MaineHD
MaineHD is offline
Guys i was away for the weekend and dint have time to check in, thanks for all of the replys. I have to say i really think its coming from the front, and ive pretty much now ruled out the front caliper, and like i said, it does it very occasionally, like maybe 3 mins out of a day of riding...Ill check my motor mounts next i guess..
Best,
Old 05-14-2007, 08:22 PM
hounddog's Avatar
hounddog
hounddog is offline
ya motor mounts in pertickular the top mount on the left side. i had this noise told the stealer on my 10k service and they said it was the primary chain. but guess what it still did it and i found out that by grabbing the horn and pulling back on it the sound stopped so when i got home i took it off and that opened up the view and i saw the back bolt on the top mount was loose and i could actully get a finger nail between the washer!!!! i tightend it up and the noise stopped. the sad thing is on the stealers CHECK list this mount was one of the line items and it was check that its tightness was checked!!!! F*ck bastards i never went back third time was the charm for me. 3 times i got my bike back with loose ****. i about lost my whole stock ac after they did the 1,000 mi service cuz only one of the 3 bolts that hold the bracket to attach the cover was in the others were just rattling around.
Old 05-15-2007, 09:53 AM
MaineHD's Avatar
MaineHD
MaineHD is offline
Thanks for the tip on the Motor Mounts, its rainy this week here in Maine, so ill check em over.
Best,
Joe
Old 05-15-2007, 01:50 PM
hounddog's Avatar
hounddog
hounddog is offline
good deal im almost sure thats what it is cold be wrong but what you discribed was exactly what i had and that top mount was the trouble maker. glad to help in anyway even if its from my own stealers failures!!! lol
Old 09-23-2010, 12:53 AM
Horcat's Avatar
Horcat
Horcat is offline
4th Gear
I have a similar problem with my dyna chirping. While I agree you should check your motor mount, you should check your drive belt to see if it is wearing against either side of the sprocket... it is easy to see, just look at the belt from behind. We adjusted my rear alignment just slightly and the chirping went away. About to so it again this afternoon.
Old 09-23-2010, 01:35 AM
roadgliderick's Avatar
roadgliderick
roadgliderick is offline
same problem it was the rear belt it was loose
Quick Reply: Chirping, rattling sound from my dyna is driving me loco
