Been painting my own bike!
Old 04-28-2016, 09:55 AM
Dyna_Bagger85's Avatar
Dyna_Bagger85
Dyna_Bagger85 is offline
These are going on the sides of the tank. All the parts in black will actually be white and the white parts will be OD Green
Old 04-28-2016, 09:58 AM
Dyna_Bagger85
Originally Posted by robbyville
You are the freaking man, talk about amazing McGuyverism (sp?). Can't wait to watch to progression thanks so much for documenting!
Did you already have a paint gun?
I got a paint gun set about a year ago and just now getting around to using it. Took some time to figure out which **** did what since there was no manuals.
Lol and learned one time to make the needle is in so the paint won't run out of the gun and get EVERYWHERE!!! Also learned from a local painter that once the paint was out to run air through it for a minute and then use some laquer thinner to spray through it and clean up will be super easy!
Old 04-28-2016, 02:35 PM
Dyna_Bagger85
Have to do the fairing and hand guards still and then a few more coats on all of it!!
Old 04-28-2016, 02:49 PM
thor05deluxe's Avatar
thor05deluxe
thor05deluxe is offline
In for the final product... I like your booth, that's a good idea.
tnriverluver's Avatar
tnriverluver
tnriverluver is offline
I'll make one more suggestion. If you have never sprayed clearcoat before, find something to practice on before spraying your tins. Clear will run on you and you won't see it sometimes until it's too late. It really is very different than spraying the base color.
Old 04-28-2016, 03:25 PM
hsr's Avatar
hsr
hsr is offline
Very cool! Looking forward to seeing the finished product.
Old 04-28-2016, 09:33 PM
2500hdon37s's Avatar
2500hdon37s
2500hdon37s is offline
Received 1,549 Likes on 667 Posts
Gonna look great!
Old 04-28-2016, 09:41 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
What kind paint and gun you using? Cost?
I've toyed with the idea of paintingy own stuff bit never pulled the trigger. I've got some experience with scale models but that's quite a different thing.
Old 04-28-2016, 09:47 PM
Dyna_Bagger85
It was a 10 piece set I got on Amazon for $85
Old 04-28-2016, 09:50 PM
cggorman's Avatar
cggorman
cggorman is offline
Gravity feed?
I've got a couple old siphon feed DeVilbiss guns that should work OK if I got a moisture filter but all the pros seem to use gravity feed.
What kind of paint? Where did you get it?
Quick Reply: Been painting my own bike!
