Looking to replace my Progressive shock springs
Hello...
Last year I installed Progressive springs and shocks to my Dyna. Overall, it was a good upgrade. I elected to go with heavy duty components. The forks are great but the shocks are a bit too stiff. I weigh about 260- 265 lbs. The preload on the shocks are fully backed off and harsh bumps will jolt my lower back. But what really annoys me is the rear of the bike is too high. There's not enough sag. Cornering feels awkward. I want to go with standard springs (430 series, 12.5 in) P/N 1442-20B/30. were is a good source to order these? I've looked on Progressives site and around the web but I cant locate anyone selling these springs. Any guidance would be great. Thank you
Call progressive directly - they are easy to work with
or
http://www.jpcycles.com/motorcycle-s...ive-suspension
http://www.dragspecialties.com/produ...oductId=248136
http://www.ebay.com/sch/i.html?_nkw=...+shock+springs
Ghost
or
Ghost
Like Bigbadpoppa, I highly recommend Ohlins shocks. I bought a set over the winter from Howard at motorcycle Metal and it was by far and away the best off season upgrade I have done. Give him a call and explain your needs and wants and he will suggest several options that will get you what your looking for.
or
Ghost
or
Ghost
Called Progressive today and got my replacement springs on order. I'm sure about the right part number. They'll only set me back about 75 bucks plus shipping. I wasn't on the phone with them for 5 minutes! Now I need to figure out how to properly dismantle the shock assemblies correctly. They should get here Mon or Tue.
orielly / autozone will "lend" tools with a deposit..., that'll be refunded when the tool is returned
Remove shock from bike - compress spring - disassemble - remove spring
Reverse to reinstall
Notes:
Tighten both compressors equally..., and in small increments (also loosen in same manor - otherwise things can go to hell..., quickly)
Don't go ape compressing the springs - just need to remove tension
Wear safety glasses
This very similar to working on coils / struts - on a cage (and all the same precautions apply)
If you're not comfortable - remove shocks..., then take em.., and the replacement springs to an indy - should be a quick turn around..., and relatively cheap (and if either ain't the case - find another indy)
Ghost
Notes:
Wear safety glasses
Ghost
Wear safety glasses
Ghost
By far one of the most scary experiences I've ever had working on any type of vehicle.....
