Can't find White Walls on 2011 Wide Glide
Old 08-24-2017, 08:07 AM
Standup303's Avatar
Standup303
Standup303 is offline
6th Gear
Default Can't find White Walls on 2011 Wide Glide
Hey guys, I have searched for hours trying to find a 80/90/21 Front and 180/60/17 set of white walls and cannot find anything! I have seen the front and it is ok to step up to a 90/90, I've seen the rear in 200/55/17-however, Dunlop specs 5.5" wide wheels while ours are 4.5". I am not spending money to swap a wheel just for a white stripe on my tire.
Does anyone know of a white wall tire that will fit the rear? Or even a 190 that specs a 4.5" wide wheel is acceptable?
Thanks in advance
Old 08-24-2017, 10:52 AM
JohnMn's Avatar
JohnMn
JohnMn is offline
Google is your friend;
https://www.google.com/search?q=180%...utf-8&oe=utf-8
just do the same with the front,,
Old 08-24-2017, 11:26 AM
Standup303's Avatar
Standup303
6th Gear
If you actually click on any of the links in the Google shopping images or any of the search links shown, ZERO of those are actually 180/60/17 white walls.
Vec (08-24-2017)
Old 08-25-2017, 01:26 AM
JohnMn's Avatar
JohnMn
JohnMn is offline
Your nit-picking. If you really want whites then you'll need to compromise a little eh?
Old 08-25-2017, 02:32 AM
AntonZ1's Avatar
AntonZ1
AntonZ1 is offline
"White Wall Toppers, Port-O-Walls and White Ribbons, there are several names depending on who you know. One thing for sure is that these are so simple to install and it will change the entire look of your ride.
You don't need to buy white wall tires when you have a simple alternative such as these; and we all know how costly WW tires can be. The secret of our Port-O-Walls are the inside edge that's pinched between your existing tire wall and the lip/rim of your wheel.
When they wear out from age, simply buy replacements. We offer these as singles (1 ea.) just for that purpose.
White Wall Toppers come in standard "wide" white wall or white ribbon "skinny" types for automobiles. We also carry motorcycle sizes in for a variety of applications."
http://www.mooneyesusa.com/product-p/ww14.htm
r1cochet (08-25-2017)
Old 09-19-2017, 11:42 PM
MidnitEvil's Avatar
MidnitEvil
MidnitEvil is offline
Man! I hope you never find them. That would look awful!!!
Hogpro
08-12-2014 12:11 PM
Chopperz
06-27-2009 10:59 AM
donr101395
02-27-2009 05:31 PM
beary
06-18-2008 06:36 PM
WouldBeHD
04-30-2008 09:48 PM
Quick Reply: Can't find White Walls on 2011 Wide Glide
