It cracked......so I chopped it off!
Just finished chopping my rear fender (after it cracked), and relocated turn signals and installed side mount with 2 plate bolt lights from TC bros. Of course I'd like the fender to really hug the tire, but the 180
and slammer shocks helped lower it a bit. I think I can live with it. 😀 I like the look from the back
Looks better from directly behind than this
I like it, however (just my opinion, PLEASE don't take offense) I think it would look better from the side if you were to cut a little more off so the angle is going similar to an exhaust til (if that makes sense). I tried to edit the pic so anything behind the line would be cut even with the fender struts, but not cutting the fender struts. I'll try to find a pic online of one that shows what I'm talking about better.
Received 5,058 Likes
Dude, get a piece of string and tie it around the axle and pull it tight to the high point of the fender where you cut it. Then draw a line down the sides, that is where you should cut the sides. It will look much, much better. This way the cut will be a radius line from the center of the wheel.
I did the same thing on my Sporty, I got rear ended and it was the easiest way to fix the problem, just cut off the dented part. Good luck.
It just "cracked". I guess the 2012's have quite a history of this........as I learned after doing some research. The way the fender lays back, with the tailight mounted on it, along with the license plate, and then the vibration from aftermarket exhausts, tuners, etc, the damn thing just vibrated too much and overtime they crack! Look up Dyna rear fenders and cracking issues and you'll see what I mean. I only did this job because I didnt want to have to buy another fender.........plus I look doing a little wrenching.
