FXDLS cartridge side tube cap removal?
Not sure where u got lost. The top of the cartridge threads into the top cap. No big deal. You just have to actually look at the thing. Use a wrench on the rod and loosen the cap. Separates and comes right off. I know its a LRS, I have one and have done the suspension on it.
Not sure how a preload adjuster on the right side suddenly makes it work like the cartridge setup? But it doesnt. Its a inadequate solution to an already inadequate setup. Kinda a weird setup youre using there with the extensions and preload adjusters with a stock setup (especially if youre running the 12" shocks still in the back).
^ I'm not...I'm running 13.5" Ohlins, so this will be perfect, hence why I'm doing it.
and wasn't saying it'll work like a cartridge. I'm saying having pre-load only on the right, (spring side) should help, considering there's a cartridge system on the (left) side only.
and overall, I'm trying this because I think this will not only help with the ride performance, but give me the extra travel I want as well, for $150.
OK, cool. Just from the sound of the mods kinda slapped together for a stock bike. For the back youve spent..... Id say save the 150.00 and spend the same on the front as the back. The stock front is junk for aggressive riding. + over stock tubes arent that expensive. I swapped mine for my dual cartridge setup because I couldnt use the stock left side. And go with a conventional spring setup and adjusters or dual cartridge setup. Youll be happier and money spent well.
