Will Harley rigid solo rack fit low rider s
It will fit, even though Harley says it won’t.
you will need to remove the rear fender to install but it’s pretty straight forward.
i replaced the rear indicator bolts with some longer ones at not much cost and if I remember one of the plastic plugs that hold the indicator cable up under the fender will no longer fit but it’s an easy fix with some gaffer tape underneath.
EddieBrock (06-09-2019)
EddieBrock (07-02-2018)
timberwolfz28
09-01-2008 07:00 PM
