Krator t-shirt fairing (Amazon)
#31
@DynaKid94 Are you a San Diego local? I've seen you around the forums for the past few years and it sounds like you're running this fairing. I have an fxdx so I'm gonna have to drill my triple clamp and was wondering if I could find someone local running the Krator. I already got all my **** for it but just want a more accurate vision of how this thing mounts before putting holes in my scoot.
#32
Aight 10 4. My dyna has the stock fxdx cowl over the light, and I gotta put my new bucket on the bottom clamp because mine is top mounted. Could you possibly take a picture of how your bucket attaches to the bottom triple clamp? Also I'm assuming you're running the JD relocation block? I bought the Memphis shades and am debating if I should just trash it and dish out the $65 before I start.
#33
#35
#36
#37
From what I gather, you have 3 options. The easiest and cheapest is probably just drilling the lower triple clamp and plopping a bottom mounted bucket on there. The cleanest is buying the factory fxdxt upper and lower clamps but that cost money and more work than I can put into the bike right now. Then the last is fabbing up some kind of bracket that puts quick release grommets at the bottom of the fairing and running two quick release clamps on the forks. I don't know how stable or good that'll look though. The headlight may be in the completely wrong place. I'm going to get ahold of JD Customs and see what size to drill the hole, then I'm going to go up a few sizes and drill a counter sink hole to give the bolt head a firm backing point.
I'm also going to talk to a few buddies and see about cutting the windshield down to remove the curved lip at the top.
#38
#39
Getting there..
I'm getting mine on my FXDX. No drilling... no relocating headlight beyond using the block that I had when running my Ness fairing. Once I get it all failed in I'll let you know exactly how. Heres a pic of it mounted - I'm gonna have to mount another bracket or adapter to make it really solid... but I'm getting there. I wish they had instructions with this thing on which nuts an bolts go where when installing the windshield!
#40
