Streetbob tire sizing
Welcome from NE AR michelin commander 2 180 back 110 front. When I needed a new set kept 160 on back and switched to 110 on front made huge difference, in handling i.e. grooved pavement road snakes.
180 is the widest....I think bluebob is running a 200 but he had to do some work to get there....
but only certain tires will fit that 4.5” rim.
Check here...
https://ridewrightwheels.com/pages/m...-fitment-chart
Check here...
Check here...
Check here...
For the front I laced a 3.25" x 21" and mounted a 120mm 70 21" Avon. Really feels good now!! I built my own tire irons / bead breaker / truing stand / even made my own stainless spoke weights. Wide glide trees / AN BBK Tokico caliper.
crusader1xxx (11-08-2018)
The widest tires I have found to fit on the stock 17x4.5 wheel are the Michelin Scorcher 160/70-17 @ 6.97 & the Bridgestone Battlecruise H50 180/60-17 @ 7.24, but the BS was measured on a 5" rim so it's probably more like 7.1. The Mich Scorcher 180/60-17 is 7.6, but it's minimum wheel width is 5" & it would be a tight fit & might need a little work on the rear fender. All of the 180 mentioned above are mounted on 16" wheels.
