1996 wide glide exhaust
Here is the procedure, starting with the front:
install lower nut finger tight
install upper nut to 9-18 in/lbs.
tighten lower to 60-80 in/lbs.
tighten upper to 60-80
repeat with the rear nuts
NOTE: these are inch pounds, not foot pounds
If you are referring to the flange nuts, be sure to check them after a couple of heat cycles to see they haven't loosened up.
RottentotheCore
08-03-2013 11:29 AM
