Does this stator look good or is it going bad?
Old 01-27-2019, 04:08 PM
SmittyFXDL's Avatar
SmittyFXDL
SmittyFXDL is offline
Default Does this stator look good or is it going bad?
Stator looks pretty good except for that area with that looks like hardened silicone or burned goop. Is this normal or does it need replacing?
Old 01-27-2019, 04:35 PM
DTTJGlide's Avatar
DTTJGlide
DTTJGlide is online now
If it doesn't stink like burnt real bad it's probably ok, the only real way to tell is to run it & check output. Was it charging before you pulled it apart?
Old 01-27-2019, 05:30 PM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
It's done. Get a Cycle Electric.
Kingglide549 (01-27-2019)
Old 01-27-2019, 05:37 PM
J_MOSH's Avatar
J_MOSH
J_MOSH is offline
I can only assume your in there because you have been having issues. Replace it. Even of you haven't been having issues you probably will soon. It would suck to have to rip it down again after a month or so of riding.
Old 01-27-2019, 05:54 PM
SmittyFXDL's Avatar
SmittyFXDL
Haven't had any charging issues. Did have a broken inner primary bolt that needed extracting and a leak from the stator plug.
Old 01-27-2019, 09:12 PM
DTTJGlide's Avatar
DTTJGlide
What year bike & how many miles?
crusader1xxx's Avatar
crusader1xxx
crusader1xxx is offline
For the cost, I would change it..cheap insurance....cycle electric are supposed to be good.
Old 01-28-2019, 06:09 AM
Campy Roadie
As mentioned in this post ^. Even though you don't have charging issues at this moment, that stator needs to be replaced. OR, you can wait for it fail (and it won't be long) and you can buy a battery and possibly a regulator/rectifier; then you can take it all apart to where you are right now.
Old 01-28-2019, 07:18 AM
John CC's Avatar
John CC
John CC is offline
Well, it looks nasty, but, it also looks like it didn't come from the stator. If that's the case, why condemn the stator? (If it did come from the stator, then obviously there's something wrong with it.)
[Edit] Where did this bit go?
Old 01-28-2019, 07:42 AM
70copperz's Avatar
70copperz
70copperz is offline
It looks like that was riveted on. That pic is of my 08 Fat Bob, so you're stator might be different since your bike is newer. To tell you the truth that's the first time noticed that. The new stator that I installed from Cycle Electric didn't have that.
Quick Reply: Does this stator look good or is it going bad?
