Rear Wheel
pjdude (02-26-2019)
If the hub is fine then order up a set of stainless spokes and a new rim thats mabye a hair wider, depends on taste. And spend some time lacing her back up. Its a good skill to learn and if someone needs theirs done you can make a litttle side cash. Unless its a brother, i have never and never will charge a brother to work on his bike... i just make him help me so he learns.
You sure Multi? .. I thought the only difference was the bearing ID... not the bearing OD... hub didn't change I didn't think.
Not OD (that's the same 52mm) ...I'm Talkin' Width
and YES, the Hub changed
See my SIG ... 9247 (1" ID) vs. 9276 / 9276A / 9276B (25mm ID)
I don't make this stuff up ... I just Learn it
EDITED to Later ADD
Before any Readers' ... "Yeah, but Harley's "Parts and Acessories" lists the same wheel (part#) for 2006-later, how can that be?"
Well, here's how ...
It's now 2019, HD sells you a 2006-07 Designed Wheel and then you buy a Bearing Shim to put under the Primary Bearing to move the 08-later Thinner bearing out to the proper position if you have a 08-later bike.
That's not True on Original Wheels to the bike, because of course 2006-07 was before the Design Change
EDITED to Later ADD
