Duel front brakes vs Single
I back up what someone said earlier. I am a proponent of the Ness Big Brake single rotor. I installed it on my 2012 FXDC and I am very satisfied with it. My bike is configured for performance running (jacked-up Ohlins suspension etc etc) and the big single front brake works fine. Hand feel is good too.
I considered going to a dual brake set-up but considered other options first to avoid the front end clutter and added un-sprung weight of the dual system. First, I tried a Performance Machine (PM) 6-piston caliper on my stock rotor. The PM caliper looked great but it was not as strong as the stock caliper. I then went to the Ness Big Brake and re-installed my stock caliper. I'm satisfied. It works fine and looks great to me.
Location: Depends on who wants to know.........and why.
Received 1,901 Likes
I'm also putting Lyndall Xtreme pads on it.
The brakes on my Harley suck! Well at least compared to the Kawasaki they do!
Thanks for the compliments MMH and SixDD
That exhaust is a Vance and Hines "Upsweep." It's a relatively new system from them. As with the other things I've bought from them, it is first-class quality. It comes with a removable baffle (takes some fiddling to remove it) and I am currently running with the baffle in. Sounds great to me. This is not a quiet system - even with the baffle inside. I am also running a modified ECU done by their removable FuelPak 3 FP3 module. This bike hauls ***. It will run with my new BMW 1200GS - even on a curvy road.
That Upsweep exhaust allows me those deep right-handers where I would otherwise be scraping something even though the bike sits up 2 inches higher than stock.
By the way, I'm also using one of Alan Sputhe's drive train stabilizer kits.
Have a good time.
I also put on a sputhe stabilizer. In addition, a predator front mount and a real heim joint for the top engine mount.
