Wide Glide Front End
Hey fellas, good to be a part of the community here. Long time lurker and figured it was time to join the ranks!
Im in the DC Metro area and if there's anything I can do to help, whether it be bike or beer related, just let me know. Now, time for my question/project: I picked up a 17 wide glide with crazy low miles about a month back and grabbed it since a wide glide has been on my radar for years. The test ride was pretty basic and I was blinded by how F* sexy she is, but as I continue to ride the bike I have noticed that its handling "characteristics" are odd to say the least as I'm sure you are all aware of. I was thinking about going the fat bob triple tree route and was hoping that someone who has experience with the mod or a good understanding of it would chime in. I understand that the fat bob trees are 0 rake and am concerned that leaving the stock wide glide forks on will raise the front end too much. Would it be best to use fat bob forks as well? How will this effect the ride height and the rear end positioning? Also, what components should I go ahead and pick up to make sure all is well? Would it be beneficial to also relocate the controls to the mid-position? I want slightly quicker handling, better low-speed maneuverability for city traffic and a more solid front end when blasting down the highway (particularly rut and tar snake infested roads here in the area). Thanks guys! |
I'm going on a 2-3 day road trip in the morning so I'll keep this brief, I have done this mod and returned back to stock WG. It offered everything you mentioned ( stability, quicker handling, solid feeling) I went back to WG because I didn't like the looks.
If you can wait a few days and think about what you're going to do, I can help. I have FB tree and tubes with Progressive springs and WG lowers on them that are available. You might also explore putting a wider rim on your WG and running a wider 21" tire. I run a 120 and stability has improved dramatically. |
Originally Posted by joe40x
(Post 18322970)
If you can wait a few days and think about what you're going to do, I can help. I have FB tree and tubes with Progressive springs and WG lowers on them that are available. You might also explore putting a wider rim on your WG and running a wider 21" tire. I run a 120 and stability has improved dramatically. Thanks buddy! |
(Post 18322970)
Originally Posted by Blue Bob
(Post 18323274)
The 3.25" x 21" with 120 front tire is one of the best mods I've done.
which wheel did you end up going with? Did you relace the hub or is there a direct swap out there? thanks again. |
Originally Posted by chop13
(Post 18323282)
Thanks for the input man! I have been considering going this route as well, even if I keep the front end swap off until winter.
which wheel did you end up going with? Did you relace the hub or is there a direct swap out there? thanks again. https://www.hdforums.com/forum/dyna-...-spokes-3.html |
(Post 18323311)
Here's a complete writeup for an economical way. Just beware the chrome plating is cheap! but great if you powdercoat.
https://www.hdforums.com/forum/dyna-...-spokes-3.html I still like the street/fat bob front end option, but will do this regardless as either way it is beneficial. Thanks for the info my man! |
(Post 18324976)
Now that's a pretty nice option. I may go ahead and PC one and give it a shot at lacing the wheel. Never did a lace job as it seemed way too complicated. Can I relace the hub and have a dealer true and balance it (no real indy shops near me).
I still like the street/fat bob front end option, but will do this regardless as either way it is beneficial. Thanks for the info my man! Most dealers just sub it out and charge too much...they don't have the volume or staff to make it profitable. My wife completely disassembled my wheels and polished the spokes. I made my own stand / laced and trued / mounted my own tires / made my own wheel weights and balanced https://cimg1.ibsrv.net/gimg/www.hdf...1427dd721c.jpg This is the rear 200mm. |
(Post 18325036)
Your Welcome. Yes lace yourself and take to dirt bike shop....they lace all the time and charge much less to center and true....Heck you might even find a bicycle shop that would take it on. Make sure you measure your rim offset before removing spokes.
Most dealers just sub it out and charge too much...they don't have the volume or staff to make it profitable. My wife completely disassembled my wheels and polished the spokes. I made my own stand / laced and trued / mounted my own tires / made my own wheel weights and balanced https://cimg1.ibsrv.net/gimg/www.hdf...1427dd721c.jpg This is the rear 200mm. Rim offset? Best way to measure? now, how did you go about making a 200mm work on the rear!? |
(Post 18325036)
made my own wheel weights.
© 2024 MH Sub I, LLC dba Internet Brands
